AEM CAI & Check Engine Light
Old Dec 16, 2003 | 09:27 PM
trigeek's Avatar
Default AEM CAI & Check Engine Light
I just had the AEM CAI installed by a certified Honda mechanic. I picked it up and went straight to work and everything was fine, no lights. When I started it after work the CEL did not go off after a few seconds. It was on for the drive home, 8mi. I checked all the hoses, everything was tight. Has anyone had this happen and if so what did you do? I will be calling the shop first thing today. My S is a 04 and to see the CEL on made me sick
Old Dec 16, 2003 | 09:32 PM
sebrings2k's Avatar
sounds like your vacuum hosing could have been installed wrong.
http://forums.s2ki.com/forums/showthread.p...threadid=105368
check this thread and see if all of your hosing is going into the right places.
Old Dec 16, 2003 | 09:58 PM
MacGyver's Avatar
See my webpage for some install and hose pics...
Old Dec 16, 2003 | 10:06 PM
Fapout's Avatar
I'll tell you what it is. It's the plastic piece that connects that 2 hoses down at the bottom by the metal cross bar. If it's backwards it won't create a vacuum. It's a one way tube. Anyway. Just flip it around and you won't get the CEL.
Old Dec 17, 2003 | 01:12 PM
MacGyver's Avatar
The one way portion is actually the small white checkvalve...the black piece is two way.
Old Dec 17, 2003 | 02:19 PM
hondaS2001's Avatar
Banned
is everything the same along the intake on the 04, as you said yours is an 04, as the 00-03's? If so then it can only really be what the other members have suggested, not only the check valve thing, but make sure he routed both hoses to the correct places, I believe having them reversed would also throw a light.
Old Dec 18, 2003 | 05:34 AM
trigeek's Avatar
Thanks for the info it really helped. I went back and it was the vac hose. I was in and out in 5min.
Old Dec 18, 2003 | 06:03 AM
Quik S2K's Avatar
--> MOVED TO UNDER THE HOOD <--
doinou88
Feb 10, 2008 06:55 AM
krazyguy316
Jul 31, 2006 04:01 PM
woo
Jan 18, 2006 08:36 AM
USCstudent
Dec 20, 2004 04:53 PM
sman
Feb 14, 2003 06:43 AM
