AEM COLD AIR INTAKE ISSUE
Guys Im having a problem. After Installing my AEM cold air intake on my 01' S2k, the check engine light was expectedly on after a short while.. I cleared it through a friend at his garage. Now the light keeps coming back on..... Is there a way to Bypass this... so it doesnt keep coming up? Do i need a resistor over the mass air flow sensor??? im stuck,,,
you should check your hoses and vacuum lines. you probably connected your hoses back up improperly.
read here for proper hose routing. this is available in the FAQ at the top of the technical forum.
https://www.s2ki.com/forums/index.php?showtopic=105368
also i'm moving this to UTH, as it doesn't really belond in technical
