AEM EMS Fitment
Old Jan 12, 2004 | 02:39 AM
vapors2k's Avatar
a custom harness that would extend the wiring to mount the ecu behind the seat would be very nice.
Old Jan 12, 2004 | 09:56 AM
GaryRudolph's Avatar
Yep, I'm making sure to take pictures this time. I'm also trying to document what I did for the AEM UEGO, and larger injectors.
Old Jan 12, 2004 | 11:02 AM
vapors2k's Avatar
perfect, are you making the harness? or having it made? I could do it but I need both female and male adapters.
Old Jan 12, 2004 | 12:50 PM
Actually, I'm not going to go with a harness. I'm going to cut the [2] bracket, fold it over and fit the ECM up there.
Old Jan 12, 2004 | 12:53 PM
beroznikmal's Avatar
Pls do take many many pictures....
Old Jan 12, 2004 | 05:45 PM
Sideways's Avatar
To hold the kick panel back so my foot can rest on the dead pedal, I built a bracket. The bracket uses the deadpedal to lock in place. I have to undo the two 10mm bolts in the dead pedal to access the ECU, etc. The original fastener is just too short to close by 1/2 inch or more.
Please excuse the low light photo.
Old Jan 12, 2004 | 08:11 PM
honda9krpm's Avatar
Looks like a good idea sideway
I am a little bit more lucky as the ECU is on the passenger side for the s2k in my country
Old Jan 12, 2004 | 08:45 PM
Sideways's Avatar
Once upon a time I was down under.....had a great time. I let others do the driving.
Old Jan 14, 2004 | 02:23 PM
Finally, go the AEM EMS fitted and the kick panel installed in the stock ECM location. Here's what we did (based on the advice we got).
Cut the rear mounting tab [2] with a hack saw. Note where we cut. This way we can always spot weld or use some epoxy to if reinstall the stock ECM at some point.
Then, bent the tabs over on [2]. To bend back we should be able to use a screw driver and vice grips.
Others were able to mount their EMS in the normal configuration, but I was able to fit the EMS better if I turned it over (with the EMS sticker facing the sheet metal. This allowed the EMS to fit better with the serial cable installed. I just liked it better this way, and I had a harness laying around that I had made for the Vortech timing box install that I could use to lengthen the A connector. I was able to gain an inch or so more room.
Put some velcro on the "sticker side" of the ECM.
I then had to lengthen the A Connector using a harness that I cut apart.
With the connector the cables fit in pretty well.
And the following is the EMS tucked up and away and ready to install the kick panel.
The kick panel still doesn't sit like stock, and I couldn't install the clip on it near the dead pedal. But, it doesn't get in the way, and only sticks out maybe a half inch. I think I'll fabricate a little holder like Phil that attaches under the dead pedal to give me the stock room.
Old Jan 18, 2004 | 05:42 PM
FYI, Jaker (www.vtecfrog.com) can make a 5 foot harness for a "reasonable" price. Just PM or Email him. I wish I had this in advance, because I would have definately gone this route and just relocated it. But, I'm going to leave it in the OEM ECM location as I now have it crammed in there, and don't feel like taking it out.
