aem install
Old Apr 26, 2005 | 07:20 AM
S2kNY's Avatar
Default aem install
can somebody post or pm me some step by step instructions for installing the aem v1 intake on a 2001. I don't have the directions, it seems easy enough but I want to be sure what I'm doing. I also don't want to remove the whole bumper, I'd rather take off the wheel and go through the wheel-well. I also want to install the "umbrella" but don't know if I should order one from e-bay or use the flower pot idea? Will the pot get in the way of anything or will it stay mounted without cracking or breaking? Also, what can you mount it to? Any help with any of this is really appreciated. - thanks
Old Apr 26, 2005 | 09:46 AM
acuraintegraman's Avatar
not that difficult imo, but I don't have pictures. If you go here you can see Chiung's install of a v2 which is very similar. I used these to help me when I did my install a mt ago. Anyways, instead of the hole he drilled on the splash guard, I did a slit cut but everything else is similar. I didn't remove bumper or wheel, but did remove the splash guards.
As for the pot, just use anything that will direct water from the drain hole away from the filter. I used a pot and zip tied it to a couple of holes that were pre existing. Before you put the filter on the pipe, look above for the many holes that are available
Old Apr 27, 2005 | 08:16 AM
S2kNY's Avatar
Thumbs up
do you have any pics of how to remove the bumper? I want to install it without taking off the bumper but it looks like it will be hard to trim all that plastic without being able to get your whole arm in there, or is it possible?
Old Apr 27, 2005 | 09:22 AM
If you look into the faq section, there should be a post on how to remove the bumper. For me, I just unbolted the splash guards, basically the big one in the middle and the one under the passanger side. Installed the aem, cut the plastic, then bolted the plastic back in and put the filter on.
Old Apr 27, 2005 | 04:08 PM
beanolo's Avatar
i jus took off the right wheel to cut the plastic.. didnt take off the bumper..
but installing the umbrella thing might be kinda hard from jus the wheel well...
Old Apr 28, 2005 | 06:42 AM
S2kNY's Avatar
I lost the instructions for the install, do you have to disconnect any hoses or relocate anything? I want to put in my intake asap but it seems a little harder than intakes I've put in other cars. I want to put in the umbrella also so the bumper removal might be needed. That's why I really needs some pics and directions on how to remove the front bumper (where are the clips, screws, how many there are, etc.) I cant find it under the search function and I can't find the FAQ section. Help me please, I've had my intake for months and it needs to get installrd already. - thanks
Old Apr 28, 2005 | 07:37 AM
here is the faq
https://www.s2ki.com/forums/index.php?showtopic=108435
here is Chiung's instructions with pics for a v2
https://www.s2ki.com/forums/index.php?showtopic=171067
here is vacuum hose instructions
https://www.s2ki.com/forums/index.php?showtopic=105368
here is the pot
https://www.s2ki.com/forums/index.ph...pic=284873&hl=
here is bumper removal
http://www.ricks2k.com/info/instructions/diffuser.pdf
That should be everything you need. Like I mentioned, I did not remove wheel or bumper, but if you feel like it would help your install, go for it. Now go install your intake and report with the results
brandonb
Feb 18, 2008 01:15 PM
mahin
Jul 2, 2005 12:59 AM
pleasework
Apr 17, 2004 05:16 PM
silverstone2003
May 9, 2003 12:22 PM
lambda75
Jun 2, 2002 04:31 AM
