AEM V2 CAI INSTALL
I searched the site and found install instructions for an AEM CAI install.
Has anyone installed the AEM V2 CAI?
If so, are there any install instructions for the V2 floating around?
If you have installed, do you like it?
Carbug
Carbug
I have the AEM V2 intake...install was pretty straight forward, take your time while raining the radiator, impatience typically causes a mess, and for the cutting i used sheet metal sheers and a dremel...again patience is your friend, cut a lil bit, test fit, cut some more, test, more cutting....you get the idea. Pretty sure the instructions are on the site...the V1 instructions are the same by the way. Its an awsome intake, engines revs more freely...doesn't exactly pull harder but you can feel a slight difference. And the sound, omg the sound, deeper, louder, vtec produces cacophonic synphonies which send tiggles down your snipe. yes it sounds that good, neer orgasmic. And if your the type that likes his quiet on the way to work...it sounds pretty much stock at part throttle at highway speeds.
Hope this helps,
Matt
Hope this helps,
Matt
The FAQ thread under the Technical section has links that can be helpful. Try this for the V2 install.
https://www.s2ki.com/forums/index.php?showtopic=171067
yeah i have the AEM CAI on my S2. Its great! When v-tec kicks in, you really hear it rip. Highly recommended by me!
