After getting your used S2000
What are are the best practices to do after getting a used S2K. I changed all my major fluids (motor Oil, Diff, Tranny). God knows when the last owner did any of that. This way I start with a clean slate and can keep track.
I plan on flushing the coolant soon. I also wanted to do flush the break and clutch fluids but i think i will wait till i change the break pads on it. that might be a while though
Xviper what are your thots?....Any other important things to do? ...
ha, you tell me about it, i just brough a used s2000
motor oil
oil filter
K&N filter
coolantx2
distilled water
new cap
new thermostat
axxis ultimate pads
dot 4 syn-power brake fluid
plastic polish(fogged headlight)
swirl remover
rubbing compound
valve adjustment(diy)
timing check
compression check
diff 75/90
gm syncromesh
spoon snorkel
new(used bumper)
sparkplugs
injector cleaner
motor oil
oil filter
K&N filter
coolantx2
distilled water
new cap
new thermostat
axxis ultimate pads
swirl remover
rubbing compound
timing check
compression check
diff 75/90
gm syncromesh
spoon snorkel
new(used bumper)
sparkplugs
injector cleaner
The above covers it pretty well.
I'll add: cabin filter, silicone grease the rubber seals on the soft top and windshield edge, silicone spray all your rubber boots under the car (CV boots, steering rods boots, ball joint boots at all for corners, treatment for soft top (303), treatment for interior leather, treatment for interior plastics.
s2000-vuu
Aug 10, 2009 09:26 AM
