after replacing steering rack
Old Aug 10, 2005 | 03:02 PM
sfphinkterMC's Avatar
Default after replacing steering rack
what's the deal with resetting the EPS?
why and what is it doing, why needed, what if u don't.
do u need special dealer equipment?
thanks
GPT crash testing
Old Aug 11, 2005 | 05:36 AM
Squeezer's Avatar
you'll have to reset the torque neutral position.
special equipment isn't needed. the proceedure to do this is in the factory service manual
Old Aug 11, 2005 | 04:28 PM
Slows2k's Avatar
The SCS circuit is shorted by grounding pin#9 on the DLC.
With the ignition switch OFF, connect the HDS to the 16P data link connector (DLC) (A) located under the driver's side of the dashboard.
With the vehicle on the ground, set the front wheels in the straight ahead driving position.
Short the SCS circuit to body ground using the HDS.
Turn the steering wheel 45 degrees to the left from the straight ahead driving position, and hold the steering wheel in that position.
Turn the ignition switch ON (II). The EPS indicator comes on, then it goes off after 4 seconds.
Within 4 seconds after the EPS indicator goes off, return the steering wheel to the straight ahead driving position and release the steering wheel.
The EPS indicator comes on again 4 seconds after releasing the steering wheel.
Within 4 seconds after the EPS indicator comes on, turn the steering wheel 45 degrees to the left again and hold it in that position.
The EPS indicator goes off after 4 seconds.
Within 4 seconds after the EPS indicator goes off, return the steering wheel to the straight ahead driving position and release the steering wheel. Do not move the steering wheel before turning the ignition switch OFF.
NOTE: If the steering wheel is moved, the torque sensor neutral position cannot be written to memory.
The EPS indicator blinks twice 4 seconds after releasing the steering wheel, then it blinks three times 5 seconds after. Then, the indicator goes off. The torque sensor neutral position is memorized.
NOTE: If the EPS indicator stays on, there was an error in writing the torque sensor neutral position to memory. Repeat the procedure starting from step 3.
Turn the ignition switch OFF.
goblueS2K
Apr 27, 2015 11:58 AM
Gaffa
Jan 17, 2015 03:39 PM
agy2k2
Aug 12, 2014 11:49 AM
S_Corp
Nov 24, 2010 11:19 AM
PHAMS2K
Nov 21, 2010 06:20 PM
