HELP! Steering issue, almost wrecked the car
Old Jun 15, 2014 | 08:07 PM
agy2k2's Avatar
Default HELP! Steering issue, almost wrecked the car
I know these cars are prone to eps issues but I'm not sure what this is. At first I thought it could be bearing plates on top of the struts but after almost crashing the car i think its the rack...
So driving the car - if you turn the steering wheel, it stays put if you let go of the wheel. Steering wheel does not return back to centered. Steering is stiff but not as heavy as no power steering. Tried pulling eps fuse to see what it would do, made the car nearly impossible to drive. Whatever it is I would think its mechanical and not electrical but figured i'd ask here
Was driving down the road going 60mph and steering wheel locked up completely causing me to go off the road, thank god it was flat grass and nobody was near me
Any ideas? I'm assuming the rack is bad but never in my life have I had to steering wheel lock up going down the road. That's scary
Old Jun 16, 2014 | 01:40 AM
Intertia's Avatar
Check the steering rack guide screw, it could be over tightened. Refer to page 17-14 of the service manual.
Sent from my Nexus 5 using Tapatalk
Old Jun 16, 2014 | 02:58 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Your problem is completely uncommon. Have it checked out it wont be hard to find.
Old Jun 16, 2014 | 11:53 AM
agy2k2's Avatar
good call, i forgot about that adjustment. i loosened up the nut and still same problem, wheel wont spring back to zero. no eps light on
Old Jun 16, 2014 | 12:14 PM
Ian300D's Avatar
Ebay has whole EPS units for under $300. Good news is fixes are relatively cheap it seems.
Do not drive car until this is resolved, hope that was a no brainer.
Good luck, sounds scary as hell, glad your okay though.
Old Jun 17, 2014 | 11:19 AM
agy2k2's Avatar
think im going to order a used rack.
anyone have any input?
Old Jun 18, 2014 | 05:49 AM
agy2k2's Avatar
Used rack coming. I'll post back
Old Jun 23, 2014 | 06:03 PM
james0933's Avatar
Ap1 or ap2 rack?
You undid the eps fuse and it wasnt driveable?
Old Aug 12, 2014 | 11:49 AM
agy2k2's Avatar
Originally Posted by james0933
Ap1 or ap2 rack?
AP1, yes it was drivable but very very hard
I fixed the car. Used rack fixed the problem. Not sure what was wrong with the old one.
victory423
Oct 2, 2016 12:49 PM
Gaffa
Jan 17, 2015 03:39 PM
Master Apex
Sep 12, 2008 12:18 PM
Urge
Feb 6, 2007 03:44 AM
S2KALI
Oct 27, 2000 04:42 PM
