Aftermarket Exhuast
Old Sep 1, 2009 | 07:41 PM
Frick Nasty's Avatar
Default Aftermarket Exhuast
I have a 02 s2000, I installed a 70mm invidia test pipe & a dual 70mm invidia catback. the car had 16,000 miles when i put the exhaust on. It might have popped once or twice over a 15,000 mile period. I now have 30,000 miles and now when the car is cold it pops like a mug (it's loud)when i let off the gas. I've searched and all i came up with is maybe it's a leak in my exhaust somewhere (i.e. a gasket). Which makes sense because i just took my exhaust off the car to clean it. Thats the only thing that has changed. Just wanted to ask and make sure.
Old Sep 1, 2009 | 08:00 PM
J0eys2k's Avatar
You could be running rich, but theres many other things that could cause a poping from your exhaust Is the poping coming from the exhaust exit?
Old Sep 1, 2009 | 08:35 PM
performance wise, the exhaust is the only thing i have on the car. I haven't changed anything to be running richer. It is coming out at the exit. And it just started after 15,000 miles of having it on.
Old Sep 1, 2009 | 08:47 PM
s2k83's Avatar
You could try resetting the ecu, it sounds your running rich, thats what I would do first.
Old Sep 2, 2009 | 06:53 AM
xredjar's Avatar
The other thing I'd check (because I don't know what kind of gaskets that exhaust uses) would be to ensure all the bolts are torqued to spec.
If they use a crush type gasket....it may be good for only that first time, and you may be getting a little leak in there if it's not sealed up tight. Sucking in air when you let off from a small leak will it pop.
What your describing sounds like a lean pop, bikes that have not been retuned with aftermarket exhausts do it a lot. Just a thought.
Hope it helps.....
Old Sep 2, 2009 | 07:41 AM
MasterForce's Avatar
i have the pop too when i decel...ive had it for over a year and a half tho since i installed it. i didnt worry about it so yea.
Old Sep 2, 2009 | 10:35 AM
terahertz's Avatar
i changed all crush gaskets when i installed mine and mine pops on decel below 3000 rpm
Old Sep 2, 2009 | 02:23 PM
I like the way it sounds, it just never popped before. I was just wanting to know what changed
Old Sep 2, 2009 | 03:47 PM
skipdodoubleg's Avatar
from what I understand, it's caused by a very free-flowing exhaust (read: no cat) with very little backpressure causing a very low pressure vacuum. This vacuum pulls extra fuel into the exhaust system on deceleration. The hot exhaust combusts this unburnt fuel.
It's more pronounced while the engine is cold, since the ECU pumps more gas into a cold engine to get everything up to temps.
Either way, I heart this sound
Old Sep 2, 2009 | 07:55 PM
badboy00z's Avatar
Got any videos of it? It spits fire out when it pops right?
