Aftermarket Honda HDS obd scan tool?
Interested in purchasing an HDS setup. Something that I can run on a laptop, plug into ODB port, run some of the Honda specific diagnostics that aren't available with a generic ODB scanner.
I don't have $2k to buy an actual Honda HDS. But I see there are some aftermarket setups. But I can't decipher what is what.
There are companies selling an HDS kit, a cable and a cd for around $30. Load software onto laptop, plug cable from laptop to odb. Bought one, can't get it to work.
There is also something called a Honda HIM, some sort of intermediate hardware module that plugs into odb, then something plugs into that?
Anyone know what works, what is needed? Something a diy person that doesn't need the best, fastest, most comprehensive tool, but that will actually work?
What do I need to buy? What software do I need?
I got this setup. The reviews are positive and I plan to use it to calibrate my passenger weight sensor when I install my Recaro PP. I haven't tried it out yet but @Jub recently posted that he had success doing the same thing I'm looking to do. Maybe he can confirm if this is the same setup he got.
^ I saw the link that you've posted. Did you receive yours yet? I chose not to buy from there because it was shipping from overseas. Aside from just shipping, I was skeptical of downloading software from certain places.
I bought off ebay and don't have a physical Honda machine. I was skeptical but asked the seller some questions before buying. Still a little bit skeptical but I took the leap and it all worked out. The "Pass-Thru" cable, driver for that cable, and HDS software are what I used. I have Windows 10 Home and it was pretty straight forward.
https://www.ebay.com/itm/31417299686...Bk9SR4jHkdD0YA
Works with modern laptop, modern os, no rs-232 port nonsense, right?
Yep, laptop with Windows 10 was all I used. It states that for i-HDS (newer version), you need Windows 10 Pro. The i-HDS software seemed to run on my Windows 10 Home so I think it'll work but I didn't try using it with my car. As I understand, HDS does basically everything except they transitioned key programming to i-HDS. If you needed to re-program a key, you'd need to buy a license from Honda, etc., etc.
Nuance aside, I was able to purchase the pass-through, download software, and run HDS to my car on a Windows 10 Home laptop. Only thing I've used so far is using the re-calibration for the 06+ Pass. Seat Weight sensor. Honestly, the standard OBD-Link is much more convenient for standard CEL type stuff. I don't see me using HDS much except for these specific sensors that come up over time.
You can buy an external CD drive for like $20. You may be able to find the HDS software online but I wasn't willing to download random crap. The seller I bought from just sends .zip files via email.
midnightmethane
01-24-2011 12:53 PM
