air flow sensor
nevermind guys, i found it under the diy section...thats a wondeful thing.
thanks for all the help, i'm gonna try to clean this tomorrow and reset the ecu.
its been a crazy couple of days.....
so i did the map "whack" and pulled the cel fuse....the check engine light is still on. so i called the dealer and they told me that it read yesterday that the "air flow sensor" (i'm assumimg the map sensor) was bad.
and yes...it's $459.00 to replace!!!!!!!!! WTF?
they are checking to see if its covered under cpo warranty....i'm not holding my breath.
turned out the car threw the code P1172...air fuel sensor.
part number 36531-PZX-013.
it was replaced under warranty thank god. so it wasn't the map sensor after all. although it had all the symptoms of teh a bad map sensor.
thanks for the help guys.
by the way, there is a tsb on this for all 2006 and 2007's with vin #'s 0001-1055.
has something to do with moisture in the exhaust system...
found it on another s2ki members post...i don't know how to link it.
