Air fuel ratios
I have a 2004 s2k. I just have 12.5:1 compression pistons bored 3mm over with stage 3 Brian Crowler cams duel valve springs with titanium retainers. I also installed the k-pro ECU.
Everything is installed and the car starts up and runs with no problem. However i have been unable to get any air fuel ratio readings. The ratio stays at a constant 14.7 never fluctuates at all even if I raise the over all fuel trim. The only error code I am getting is for the rocker arm oil pressure switch and one for the secondary O2 sensor (I
On my integra gsr it was having same issue like that too. the a/f would started at 14.8 and then 5 second later run all the way out to lean and just gone. but it was fix because it was the wire issue that i did wrong. what brand did you go with?
a stock o2 sensor is a narrowband...you want a real wideband...wideeeee see??? a stock 02 will read basically as a yes or no. but a wideband will give you a wideee reading...and also it will have a simulated narrowband output that you can feed to a stock ecu,etc.
hyperpm
May 15, 2003 05:36 PM
