Air intake rerouting lines
Old Jul 21, 2016 | 12:48 PM
Micalbertl's Avatar
Default Air intake rerouting lines
I couldn't find any information on this so I am forced to ask here so I can stop having the ghetto fix I have now.
(sorry if the picture doesn't work when I first post haven't done this before)
The factory air box has a small black box with two hoses attached to it. These hoses then route into that metal bundle which contains the breather line. In the picture it is dangling. How do most people relocate this so that it isn't at risk of hitting my pulleys.
here is a link to the photo on google drive https://drive.google.com/file/d/0B13...ew?usp=sharing
Old Jul 21, 2016 | 01:12 PM
Soviet's Avatar
I have ziptied mine to the crossmember bar before. I believe it has some smaller holes you can use.
Old Jul 21, 2016 | 01:19 PM
hirev's Avatar
A few years back i disconnected these lines for a valve adjust...put them in wrong...the air pump worked all the time...there are only so many of these lines with only so many choices....like a 50/50 chance of error, so give it a try, the right way works immediately with no change in the way it runs or the trouble light coming on...you can also look at a service manual to see how they go, there must be a picture on a page somewhere here.
Old Jul 21, 2016 | 01:27 PM
Micalbertl's Avatar
Did you do anything to get more slack in the lines they seem pretty short
Old Jul 21, 2016 | 01:29 PM
Soviet's Avatar
Now that I think about I replaced them because the eventually got cut by the pullies, so I ended up getting longer lines
Old Jul 21, 2016 | 01:58 PM
sillyboybmxer's Avatar
There is a small hole on the right side of the crossmember that accepts a screw so you can use a bracket to get the lines out of the way. The passwordjdm intake install has some visuals, they include longer lines though
Micalbertl's Avatar
Do you know the size of the lines by chance?
Old Jul 21, 2016 | 05:31 PM
maxLikelihood's Avatar
i hope that I am talking about the right lines here but you're asking about the two lines that are attached to the hard lines near the top of the picture right? one forks to the left and down towards one of your pulleys and another goes into your black box (I think that is the air control solenoid). if these are the lines then they have 4mm inner diameters. i bought replacement hoses on ebay for dirt cheap (maybe a dollar a foot or something) that fit perfectly. I essentially had to replace all the hoses for my K&N FIPK intake and these were two of them. PM me for a link if you're interested.
Old Jul 21, 2016 | 06:00 PM
This is from the parts list for the pwjdm
1 Hose (Coolant) 5/8"OD x 0.25"ID x 9.5" Long
2 Hose (PCV-Air Control Valve) 23"L x 3mm OD
1 Hose (Valve Cover Breather) 12"L x 16mmOD, 10mmID
Old Jul 21, 2016 | 07:23 PM
Micalbertl's Avatar
That is exactly what I am talking about. I'll send you a pm
Thank you for the info that is a good reference. I hadn't even thought about the coolant line yet I should probably just delete the hardliners all together
S2kRob
Feb 27, 2012 09:07 AM
mnr vortx f20c
Nov 6, 2011 08:27 AM
lotus7racer
Sep 22, 2008 10:31 AM
High Revs
Jul 3, 2005 01:22 PM
JimmyB
Jul 19, 2002 04:31 PM
