Airbag SRS Light is on
Originally Posted by honda_s2k_racing,Sep 13 2007, 01:23 PM
Originally Posted by RACER,Sep 13 2007, 11:11 AM
I think the SCS connector has a small amount of resistence
I think the airbag deployment simulator tool has 2ohms resistance. I don't have one so I can't check.
I would not try to put resistance across the MES jumper, I don't know what would happen.
Sorry if I helped to perpetuate that info
Here is a snippet:
I believe someone else on the forum stated that it has 2ohms resistance. I havn't checked that personally, although I may later. Good Luck
EDIT: Honda OEM SRS tool 07PAZ-0010100 = 0ohms resistance.
Originally Posted by honda_s2k_racing,Sep 13 2007, 06:55 PM
ok so a toggle switch or just a wire wont work?
i have to get the silly tool?
its 19$ + tax ...
also, i still cant find the 2pin service connector... anyone have a picture of it?
its 19$ + tax ...
The MES connector has a yellow 2pin connector. From memory it has 2 green wires leading to it.
It is located in the cabin fusebox. It will be sitting in a "dead" socket that has no pins inside.
EDIT: Sorry, no pic. I knew where there was one in another thread, but it seems to be gone. (the pic, not the thread)
EDIT AGAIN: I wonder if your pricing the the Airbag deployment simulator? The part 07PAZ-0010100 (SCS service connector) only lists for $11.64 according to San Leandro Honda's website.
Originally Posted by SenderGreen,Sep 13 2007, 08:08 PM
The first time I reset an SRS light I used a paperclip.
Originally Posted by mikegarrison,Sep 14 2007, 02:31 AM
I have also done it using a copper wire. But since the manual clearly says NOT to do it that way, I'm not going to tell you it's OK to do it that way.
its 19$ + tax ...
its 19$ + tax ...
I guess the price is what they feel like charging
