Alignment after Compliance bushing install
I hope you used plenty anti-seize on all the bolts
And yes, I would get an aligment.
Find a place where they are able - and willing! - to adjust all 3 front settings.
Recommended front per side: max caster(*), -1 camber, zero toe.
(*) depends a bit on the chassis, everything over 6 degrees is nice, don't go over 6-3/4 degree.
Equal caster is more important than value, IOW see what the max is per side and use the lowest on both.
And don't forget the rear: -2 camber and 7-9 minutes toe-in max per side, IOW little toe-in, way less than what the computer will suggest.
So... even when....
You say: "I want little toe in at the rear!"
So... even when....
So... even when....
So... even when....
Just out of curisoty how will camber and cater effect road driving/road tire wear?
But what is perfect?
People have different driving styles, different expectations, different experience and on-and-on.
As far as I'm concerned my car handles pretty good.
Yokohama Advan AD08 (OEM 16" sizes), Koni Yellow shocks (F1/2 open R3/4 open), Whiteline front sway bar, alignment see above.
In the 5-6 years of using the alignment I mentioned before I did not notice any extreme tire wear.
I'm still on my first set of front winter tires, this winter will be the 4th season.
This summer is the 3rd season on the Advan AD08's, the rears are at the end of their life though.
The S2000 is a sports car.
One should not complain too much about tire wear.
As far as I know:
Camber = good for cornering.
Downside = inside tire wear.
Caster = good for straight line stability.
Downside = too stable and it will not turn in.
Less caster = nervous at speed in straight line.
Uneven caster = unequal turn in L/R.
There is no debate about S2000 front toe, it's supposed to be ZERO.
Front toe - either way - makes the car turn in like crap, very nervous and not stable.
There IS debate about rear toe.
I was driving around with too much rear toe for a while and it felt like drag.
I like the way it is now - in combination with the tires and shocks (setting)
And that is toe-in between 7-9 minutes.
YMMV
Ive done an alignment on my S and many other local members. There is enough adjustment in the stock adjusters to hit any kind of spec you are going for. 6.0 caster on both sides, 0 toe, and -1 camber is OE spec for the front. I believe the rear is like 0.16 total toe and -1.5 camber.
As far as I know:
YMMV
Very good info. Thanks.
news2kroller
Oct 24, 2005 12:12 PM
