alignment bolt frozen
when i got my alignment done they said that the passenger rear camber couldn't be adjusted because they couldn't loosen the bolt.
does anyone know a place that would actually put some effort into this? or maybe a pic of which bolt it is? i will use the torch at work and get it loose.
thanks guys
-Nick.
thanks guys
-Nick.
Originally Posted by Nick.,Oct 23 2009, 03:01 AM
this sounds like a pain in the ass, i should just set the other side to -1.6 and call it a day haha
i set the toe by adjusting the camber on the stuck side, then just made the other side match.
ended up with toe in the middle of stock spec, -1.9 camber on both sides.
ill fix it when i change the rest of the suspension.
Spoolpigeon
Sep 2, 2013 02:55 PM
Gatsbee13
Jan 24, 2010 09:58 PM
