Alignment issues
Originally Posted by dru5o4,Jan 15 2010, 02:56 AM
i have the exact same problem.. have u ever resolved this?
they broke my lip in the process though.. lol. jb-welded it and it broke again a couple weeks later *shrug*
heres the accident before i bought it.
i already bought a subframe so im wonderin if i change that would fix the problem... but if that doesnt work off to the frame shop it goes... hopefully it doesnt cost much
On flat ground, measure fender-to-wheel clearance on both sides of the rear.
After all the suspension parts check out, if there's still difference, it's the frame.
I had that problem.
One thing, though, is our rear knuckles (spindles) are weak, and if they're bent, they will be hard to notice.
A good frame shop will be able to diagnose what's wrong. They have to have a frame machine, and a really good tech.
I had that problem.
did they fix your problem for you? i have the same problem as you my friend, the passenger side doesnt sit the way the driver side does on my rear and i hate it! i changed out my front and rear subframe and still have the same issue. any input?
thanks! some one please help!
