Alignment settings, less agressive
Factory spec 2001-02 ...Camber front .....-0.67 to -0.33....... Caster front.....5.75 to 6.25 ... toe front -0.08 to +0.08 these specs represent 1 side of the vehicle but will be the same for both sides.
rear camber....... Ok I quit look it up in the manual... My settings are
Camber front L -.76 R -.80 Caster L 6.30 R 6.60 Toe L -.06 R -.06
Camber rear L -1.56 R -1.47 Toe L .01 R.03
Seems good for all around Ive done track days on BFG Gforce KDW had lots of rubber buildup on the inner side of the outermost tread block all four tires. I assume from heat...hardly any track experience...so I'm not sure but,
The car handling seems very predictable to me wet/dry/highway /track. Treadwear also seems even after about 5000 miles.
