Alingment advise after tein s-tech
Originally Posted by LcS2000,May 21 2009, 10:48 AM
i'm lowered on tein s techs and have the uk allignment and at speed it feels very stable
Originally Posted by s2k dre,May 21 2009, 10:56 AM
-1 degree in the front and maybe -2 in the rear. No matter what u will still get inside wear in the front. The rears will wear even.
Im rocking the UK spec. it feels fine @ speeds but it wore out my back tires too fast. Another prob is my camber is not exactly 'specd', since its dropped. furthest I could return it to was -3
if you run 0.5 and 1.5 (aka stock) and the wear is even, then that would be the best setting for tire life for you. it seems you dont corner hard enough to warrant more camber. when i lowered, i was so low that 2.3 was the best i could get in the rear, then going to the track turns out i needed more.
you can also reduce rear toe, but that will affect the handling. daily driving i can't see why not, if that's strictly all you do. that will reduce rear tire wear further.
i know you just lowered, so get it as close to stock as you can, sometimes you can't.
i know u just lowered, but what are your impressions so far?
and how many KM's do you have on your car now. do u feel any vibrations as described here?
https://www.s2ki.com/forums/index.php?showtopic=693173
