Alternative to Honda HT Urea Grease
I cannot find this grease anywhere (in a reasonable period of time). I have checked multiple sources and it's on national backorder. I'm installing my tranny/clutch and there are multiple locations that require this lube per the service manual. Can somebody please recommend a suitable alternative. One that you actually used with good, long term results.
I have found Lucas Extra Heavy Duty grease in stock, but no real idea if it's a good long term alternative..
I currently have some Valvoline Full Synthetic Moly Fortified Gray Grease and some Honda Moly 45 grease as potential alternatives.
Much appreciated.
Much appreciated.
Don't use moly thickened grease.
Use polyurea grease.
Lucas XTRA HD would be my best guess.
Park Tool also makes polyurea grease. Not sure if its rated for high temps.
I think Honda uses a synthetic base for HT Urea? Not sure. I'm also not sure if Lucas does.
Lucas doesn't seem to have the same consistency as Honda. But again, theoretically, it should function similarly.
Thanks for the quick response. I couldn't find any specs for the Honda grease. The Lucas grease seems to be high temp. "Dropping" point of 500F. I attached it's spec sheet. I'm tempted to use it, but after all I've been through to get to this point (I've now finished converting the used 2005 engine to DBW with my 2007 engine components) I really don't want this grease selection to bite me in the a** down the road. Can anyone else weigh in on an alternative that they've used with long term (mileage) success.
What area are you in? Any S2000 enthusiasts in your area that might have the grease on hand?
The wrong grease won't bite you in terms of killing the engine or trans. But the pedal may feel shitty as time goes on. And you'll have to drop the trans again. That's the risk, really.
sent you a pm
latelifecrisis (10-01-2022)
There is a green polyurea grease aviailable from John Deere
https://www.deere.com/en/parts-and-s...ease-coolants/
and also from Huskey
https://www.huskey.com/product/huske...lyurea-grease/
Could these be a substitute?
