Alternator Bearings & Rectifier
Old Oct 30, 2019 | 02:53 PM
afzan's Avatar
I also did my rectifier and brushes with ebay parts a few years ago. Been working well since then. No more dash flickering like I used to get
Old Oct 30, 2019 | 03:28 PM
Car Analogy's Avatar
Originally Posted by BrewDay09
Are you sure you're not thinking of the starter brushes? There are 4 of them and I agree they are difficult to keep in place while inserting the rotor.
The alternator only has one brush and I don't recall that being much trouble.
Here is Soviet's excellent video:
Yeah, it was alternator. My point was mostly that this job is so easy the hardest part was dealing with the brush.
Old Oct 30, 2019 | 04:23 PM
noodels's Avatar
Used to do this when I was 16 yrs old,before alternators where invented
sheeeeet !!!
Old Aug 6, 2023 | 01:27 AM
jsaric's Avatar
Originally Posted by joelzeller
Hey all, just wanted to ask for some opinions on what I should do with my "on the way out" alternator.
I assume it is original to the 2002 car with about 130k miles/~18 years, so it's getting up there in age and use..
For the last few thousand miles the gauge cluster lights have been flickering at idle and at low RPM driving. I can also hear a bearing noise from the engine bay at idle and low speeds. I am almost certain it is the alternator as the bearing noise gets louder when I turn on the headlights and quieter when I turn them off, loading and unloading the alternator. The noise if gone when I run it without the belt for a short time.
I already changed the tensioner and idler pulley bearings last year with new SKF bearings last year, they were very rough when I took them off.
So I now need to decide what to do:
1. Rebuild current alternator with new bearings + rectifier -> ~$50 in bearings + ~$215 rectifier = ~$265
  • Front bearing = 31114-PT0-013
  • Rear bearing = 31111-PT0-003
  • Rectifier = 31127-PCX-J01
2. Buy used alternator from ebay/s2ki/etc. -> $???
3. Buy Reman alternator from Honda -> 06311-PCX-505RM = ~$425
4. Buy new alternator from Honda -> 31100-PCX-J02 = ~$1050.... Yeah right...
Has anyone done any of the above? What was your experience when you needed a new alternator? 1&2 seem like the most attractive options.
Thanks! -JZ
Hi.
Buying bearings for alternator overhaul.
​​​​​​Front one 31114-pt0-013
Dim. id17, od52, w16mm
Rear one 31111-pt0-003
I'm getting two dimensions, if anybody knows exactly, please help
1. id12, od28, w8mm
2. id15, od35, w13mm
Which of theese two is correct? Thank you
Old Aug 10, 2023 | 08:36 AM
joelzeller's Avatar
@jsaric It looks like #2, id15, od35, w13
JoePhotographer
Feb 8, 2020 01:56 PM
jean-roch
Mar 13, 2019 03:16 PM
Proven_Kec
Mar 2, 2019 07:53 AM
Kyle
Nov 7, 2018 03:31 PM
Nibreezy
Dec 19, 2017 11:17 PM
