Alternator Voltage
Old Jun 1, 2006 | 11:25 PM
Stoner_1's Avatar
Default Alternator Voltage
Anyone know what the alternator is suposed to output while the car is at idle, & full load?
I'm just curious because I keep running my battery down after a 20-30 minute run. Please note that I am using AEM EMS with UEGO / Wideband O2, and that the EMS software is showing about 12.6v at 1000 RPM's. I'm thinking that the voltage should be just around 13-14 volts from the alternator under normal conditions.
Note: I used an alternator tester the other day (While the car was running), and it indicated that the alternator was ok, but the indication it looked a tad low IMO.
Old Jun 2, 2006 | 01:54 AM
Stoner_1's Avatar
Just ran the car again and tested the battery voltage directly with a calibrated multimeter. So far it looks solid at 14.2 - 14.5 VDC.... Not sure why my EMS is loosing power while the engine is off.
Anyone have an idea what could be causing this?
AFs2k
Nov 19, 2014 04:23 AM
Envied
May 27, 2011 10:54 AM
ChefJ
May 14, 2008 09:51 PM
fflatulip
Dec 10, 2007 07:03 AM
chairmnofthboard
Jul 23, 2007 11:43 AM
