Am I missing something?
Old Oct 14, 2007 | 12:37 PM
Zacreth's Avatar
Default Am I missing something?
I did a search and I can't find my answer.
I don't think I'm missing anything but the rotor won't come off the hub.
I removed the calipers, and the bracket that holds the caliper. Then removed the two philips screws on the face of the rotor. But the rotor will not budge. It will spin but I can't take it off.
Any help ASAP will help.
Thx
Old Oct 14, 2007 | 01:21 PM
NVMY4N's Avatar
According to the Thread Listed in = FAQ's-DIYs'-Maintenance Section: Under Suspension and Brake Stuff:
Located HERE
it should slide off.
it could be rusted on.
Be sure to look at the steps to see if you have missed something
Old Oct 14, 2007 | 01:26 PM
Mrfixit687's Avatar
rust, take a plastic, or brass faced hammer and hit it from behind or take 2 bolts that will fit into the other 2 holes on the rotor to take it out. wd40 or rust penetrant will help
Old Oct 14, 2007 | 01:44 PM
duanet85's Avatar
if all else fails, use a mapp gas or butane torch on the rotor where its rusted while you are hitting it with a soft hammer
Old Oct 14, 2007 | 03:28 PM
PeanutButter's Avatar
Hit is with a rubber malet.
Old Oct 14, 2007 | 03:42 PM
jeggy's Avatar
save yourself the trouble of trying to save the rotor.
hit it with a 5 lbs sledge and get new rotors.
Old Oct 14, 2007 | 07:35 PM
neeman77's Avatar
just kick it.
Old Oct 14, 2007 | 07:46 PM
BondoBuilder's Avatar
Wheel (pulley) puller. Works like a charm.
Old Oct 14, 2007 | 08:02 PM
camuman's Avatar
this one made me laugh. yeah, just wack it from the inside with a rubber mallet and your set and it wont be ruined.
Old Oct 14, 2007 | 10:39 PM
stopmenot2002's Avatar
Hit it with the hammer abit or if you could find the right size thread bolt for the two screws you took off, put the bolt on the empty hole now tight it in both bolt, as the bolt going in, it will hit against the wheel hub, and it started to separated the hub and rotor apart, you have to do two bolt to even it out. best way. Good luck.
