another post on sc belt tension
Old Sep 10, 2004 | 02:12 PM
mikecl713's Avatar
Default another post on sc belt tension
i blipped the throttle with the throttle body thingy...
it running smoothly...
when gas is let off the belt slips
i guess tighten it more??
Old Sep 10, 2004 | 02:21 PM
xviper's Avatar
How can you tell it's slipping by looking at it?
Old Sep 10, 2004 | 02:26 PM
mikecl713's Avatar
the belt starts to jump on and off the pulley..
Old Sep 10, 2004 | 03:00 PM
xviper's Avatar
How's it when doing the twist test? Something's not right. Even a slightly loose belt should not do this. Is the belt damaged in any way? How about the pulleys? Are they damaged? Are they spinning true?
Old Sep 10, 2004 | 11:28 PM
mikecl713's Avatar
i dont know...........
what could be wrong?
the only thing i can think of is that i have rick's pulleys and the clearence is very small between the belt and the water pulley
Old Sep 11, 2004 | 04:35 AM
xviper's Avatar
Rick's pulleys would only affect the main engine serpentine belt. I don't think that the engine's crank pulley is changed with Rick's stuff and thus the S/C belt should be unaffected. Something else is going on here. I would examine the S/C pulleys carefully (including the one bolted onto the crank pulley) and the tensioner mechanism.
Old Sep 11, 2004 | 02:42 PM
mikecl713's Avatar
no the rick's pulley's edges on the water pump is desgined diferently than the stock one..
Old Sep 11, 2004 | 02:43 PM
mikecl713's Avatar
i will try to post pictures/.
Old Sep 11, 2004 | 03:42 PM
xviper's Avatar
What I'm trying to say is that since it's your S/C belt that is coming off and on the pulley, this is not related to the Rick's pulleys. It is a separate belt on a separate system.
Old Sep 12, 2004 | 12:17 AM
mikecl713's Avatar
i should have made this clear.. im sorry
the sc belt is bounfing off the water pulley ..
