Another Rear End Noise Question
Old Mar 12, 2012 | 02:27 PM
dhfreak's Avatar
Default Another Rear End Noise Question
Okay, So before I get flamed, yes I searched and couldn't find anything definitive. So, initially I had some wobble and a squeak/squeal coming from the Drivers side rear wheel. I figured it was the axle nut (as that seems to be the culprit the majority of times), torqued the nut in accordance with the TSB; the wobble and noise went away for about a week. Now, the noise is back. It's a load squeak/squeal same as before, but loud enough to be heard over my exhaust. I'm thinking wheel bearing, but wanted to get a few opinions before I order one.
Mike
Old Mar 12, 2012 | 03:49 PM
FISH22's Avatar
If it changed for a bit after torquing the axle nut, then came back, I'd put money on it being a bearing/hub.
Old Mar 12, 2012 | 03:52 PM
FISH22's Avatar
BTW, if you did it IAW the TSB, it's not enough torque. Look for the DIY axle nut fix. But it may be too late, considering you already moved the nut. The DIY has to be done on an untouched axle nut.
Old Mar 12, 2012 | 04:35 PM
dhfreak's Avatar
Yeah, I meant the DIY. Do you know if there is a difference in the hubs between any of the model years? I'm pretty sure there isn't, and while I'm back there I may as well just replace the whole hub.
Mike
Old Mar 12, 2012 | 05:10 PM
FISH22's Avatar
They all share the same hubs. It's always best to replace the hub with the bearing also.
Old Mar 12, 2012 | 05:26 PM
dhfreak's Avatar
Lol, yeah that's the plan! Thanks.
Mike
Old Mar 24, 2012 | 11:16 AM
dhfreak's Avatar
So, I finally got the job done. Pretty straight forward. I used a pitman arm puller on the ball joints; definitely would have been easier with the Honda tool. Found a local guy to press out the old wheel bearing/hub and press the new ones in for $30. The hub and wheel bearing were both trashed!!
All in all, with the hub, wheel bearing, and cost for the pressing, I ended only spending $130 or so.
Mike
Old Mar 25, 2012 | 04:01 PM
EssToOfouzEn's Avatar
what were the results? how does the car feel now?
Old Mar 29, 2012 | 05:14 PM
dhfreak's Avatar
Car feels great. I didn't realize how 'squirmy' the rear end felt, until I fixed what was broken!! Now, it drives MUCH better!
Mike
Old Mar 29, 2012 | 05:18 PM
herecomesboost's Avatar
jelanier
Jul 18, 2013 06:15 AM
seansniper
Jun 8, 2011 07:45 AM
harrison1990
Nov 18, 2009 08:17 AM
waterscorpion
Nov 20, 2006 01:04 PM
elviscos
Nov 21, 2005 09:48 AM
