Any power loss
Old Jan 24, 2005 | 12:11 PM
Spoonie's Avatar
Default Any power loss
I have used the search option and have came up with nothing. I have put 3 washers around the bolts holding the cat to the exhaust so It would sound a little meaner and boy does it. Now the washers are only the thickness of a nickel so the seperation is about less then 3/8's of an inch. My question is do you think I'm losing horsepower by doing this or should I be fine until I get an exhaust?
Old Jan 24, 2005 | 01:05 PM
Elistan's Avatar
I can speculate about a couple possibilities:
1) The turbulence caused by the gap in tubing might be causing an exhaust flow restriction that reduces hp. However the fact that it's right after the cat might mean this isn't an issue. Could be you're perfectly fine power wise.
2) The hot gasses might be hitting the underside of the car at a place it's not supposed to, causing some issues with the passenger footwell.
Old Jan 24, 2005 | 02:46 PM
xviper's Avatar
So really what you've done is purposely mae your exhaust system LEAK. If you sit and idle anywhere for any length of time, CO poisoning could be an issue.
cusimar9
Jun 14, 2017 12:05 AM
LostMotion
Jan 10, 2008 12:53 AM
vtidan
Aug 16, 2006 09:41 AM
Nick Graves
May 29, 2001 03:07 PM
