Any problem using 5w30?
Old Oct 29, 2003 | 10:09 AM
amongmany's Avatar
My roommate and I split the cost of a case of oil. He needed 5w30 and I didn't think it would hurt anything. Am I wrong? I haven't used it yet, so I can still get 10w30 if theres any reason to.
Old Oct 29, 2003 | 10:12 AM
cdelena's Avatar
It will work just fine.
Old Oct 29, 2003 | 10:13 AM
amongmany's Avatar
Thanks! I thought so, but figured I'd double check before changing it.
Old Oct 29, 2003 | 12:25 PM
Bret's Avatar
If I was betting, I'd think that it would work just fine. But, Honda has specified 10W-30 for the S2000 while going to 5W-20 for most of their other vehicles. I can't imagine that this was just an oversight. Perhaps the S2000 needs the slightly thicker oil for the best lubrication? They have also specified a different oil filter for the S2000 versus the others. For this reason, I'm sticking with 10W-30 and the new (at least to the US) Honda S2000 Japanese made oil filter.
Old Oct 29, 2003 | 05:39 PM
mike2k's Avatar
After trying Syn. 10W30, 5W40 I'm very pleased with the 5W30 Syn. motor oil. Engine never needed oil added, including high speed, hard driving & track time. Planning to have the used oil analysis done soon.
Old Oct 29, 2003 | 06:04 PM
Tugz_S2K's Avatar
Banned
[QUOTE]Originally posted by Bret
Old Oct 29, 2003 | 06:54 PM
Bret's Avatar
Originally posted by Tugz_S2K
When you are in temps that do not go below freezing there is no physical difference between a 5W30 and 10W30 oil. A 5W30 oil will give you better flow at lower temperatures making it better for cold starts.
OK, so basically you are saying that 5W-30 does everything that 10W-30 will do plus it is better for below freezing temperatures. Knowing that, then why would a manufacturer ever specify 10W-30? Honda knows that the S2000 will be driven in places that are below freezing, yet they chose 10W-30 instead of 5W-30. It just doesn't make any sense unless there's more to the story.
Old Oct 30, 2003 | 06:48 AM
Gernby's Avatar
Former Sponsor
I'm sure I will restate this badly, but from what I've read, the 5W-30 will not be as stable over time as the 10W-30 due to the difference in the additive packages.
Old Oct 30, 2003 | 06:49 AM
amongmany's Avatar
What is "over time"? It's gonna be taken out in 3k miles and I check it at every fill up.
Old Oct 30, 2003 | 07:07 AM
cdelena's Avatar
[QUOTE]Originally posted by munckee
