Any problem using 5w30?
Probably not - depends on the quality of the 5w30 you are using, the ambient temps, and how hard you drive. A 5w30 mineral oil can shear down in about 3k miles under adverse conditions - a 10w30 is less likely too.
Why not run a 5w30 in winter and a 10w30 the rest of the time?
Why not 5w-40? Is the first number the weight of the oil? If the 5w pumps more rapidly at startup(more critical in sub 30s temps)why would someone go from a 5w-40 to a 10w-30?
I read the first number is the weight of the oil, while additives make the oil perform up to the second number. If 5 is half of 10, then why would it have the protection of 40(as in 5w-40). This does not make sense here. Why not go from 5w-30 to 10w-30, instead of 5w-40 to 10w-30.
If a person wanted protection against thermal breakdown, why not use 10w-40(I know honda does not recommend 10w-40, just giving example)? A fully synthetic 10w-30 would be appropriate for california in the heat of summer. Todays engines have much tighter tolerances than yesterdays engines. For example, before multiweights existed, straight 30 was a common motor oil(three times heaver than a 10w)
I dont get this 5w-40 thing
Road rage, shed some light brother. It's gettin kinda late, startin to tweak, will crash for now. later
Tireguy
Dec 10, 2002 08:35 PM
