Anyone checked your compression?
Old Sep 12, 2001 | 10:45 AM
Pepe's Avatar
I have checked the compression on four cars already. According to the service manual the S2K has 228 psi per cylinder with a max variation (up/or down) of 28psi.
The best I have seen is our race car with 255, 255, 265, 260 from cylinder 1 to cylinder 4 respectively. On the other hand I have seen cars with 230, 231, 220, 218. Still within Honda Specs but guess which one runs better.
Old Sep 12, 2001 | 10:58 AM
YoungS2K's Avatar
Originally posted by marcucci
YoungS2k, what's the deal with your #3 and 4?! That's horrible!!!
hydrolock .
waiting for a new motor.
Old Sep 12, 2001 | 12:42 PM
RT's Avatar
RT
Originally posted by YoungS2K
hydrolock .
Fuel, Water or Oil?
Old Sep 12, 2001 | 09:38 PM
YoungS2K's Avatar
Originally posted by RT
Fuel, Water or Oil?
H20.....lots of them...
Old Sep 12, 2001 | 09:42 PM
RT's Avatar
RT
where did it come from? block or intake?
Old Sep 14, 2001 | 07:58 AM
johev's Avatar
anyone know how much this compression tool is?
What is the likelihood that the dealer will do it for me as part of checking out the car?
Old Sep 14, 2001 | 11:26 AM
Pepe's Avatar
Probably $30-$40.
Depends on what kind of relationship you have with your dealer. It's a simple 20 minute job and almost anyone can do it.
Instructions:
1) First warm up the car until the fans turn on.
2) take out the spark plug/ignition coil cover (4 allen screws/mm)
3) take out the coils (10mm screws)
4) disconect the fuel injector plugs (that way they don't pulse during the test allowing fuel into the engine)
6)Take out all spark plugs
5)Screw the compression test gauge line into cylinder #1 (make sure you are using the right tread adapter/hand tight)
6)With the transmission in neutral and opening the throttle full crank (start) the engine and keep cranking until the gauge needle doesn't go up any more. Always remember to have the throttle at WOT.
7) Check it twice and move to the next cylinder.
8) When you have tested all cylinders put everything back in reverse order.
Old Sep 14, 2001 | 11:28 AM
johev's Avatar
thank pepe..I just may buy the tool and check my compression....can't hurt to check it, right?
Old Sep 14, 2001 | 02:41 PM
Pepe's Avatar
Of course not...Compression can give you a very good idea of the engine state. Lack of compression or low readings is indication that there's something wrong with piston rings and/or valves.
We check the compression of the race car after every race weekend, just to make sure everything is Ok and keep record of how the S2K holds under heavy abuse.
rikhemi
Jan 18, 2012 09:33 AM
User 121020
Aug 18, 2010 07:45 AM
Js S2k
Apr 28, 2009 06:37 PM
Sargeant Handbag
Mar 4, 2008 12:45 PM
The Unabageler
Feb 28, 2003 10:02 AM
