AP1,AP2 engine block question
Old May 23, 2017 | 12:41 AM
klemen123's Avatar
Default AP1,AP2 engine block question
My engine needs to be reblaced (main bearing faliure), so i decided to buy the whole engine block assembly.
Since the older ap1 blocks are no longer avalible part.number: 10002-pcx-316 and the newer ap2 F20C2 block (drive-by-wire) IS avalible part.number: 10002 PCX E10, i want to know if the ap2 block assembly (F20) from 2006 on... will fit my 2000 year ap1?.....
I am concerned cause the ap2 has the drive by wire and ap1 has a throttle cable.
Thank you for you answers!
Old May 23, 2017 | 03:47 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You will need to pull the timing cover on the new 2.2L DBW engine and change the trigger wheel, thats it. After that it will bolt right up and run. You will also need to be aware of rev limit.
OR
Do a Kpro conversion. It uses the trigger wheel that is currently in the new 2.2. I THINK this will also allow you to set rev limit.
Old May 23, 2017 | 10:45 AM
klemen123's Avatar
OR
it wont be a problem cause in europe this block 10002 PCX E10 is used in ap2 with a F20c engine which revs to 9000
Thank you very much for your answer billman!
Old May 24, 2017 | 03:07 PM
jyeung528's Avatar
how much is this brand new engine?
Old May 24, 2017 | 09:39 PM
klemen123's Avatar
4500€
Old Jun 4, 2017 | 01:44 PM
davidc1's Avatar
I'm curious to see if you can actually procure it. In the USA, during the last year, short blocks have been on backorder for between 2-10 months before delivery.
Shaneramsden
Jul 22, 2017 06:40 AM
klemen123
May 31, 2017 09:42 AM
will010100
Nov 12, 2016 09:07 AM
alex_KS
Dec 2, 2014 09:07 AM
Dude_Man
Sep 29, 2011 06:15 AM
