AP1 axle nut TSB gone wrong
Old Aug 7, 2017 | 05:49 AM
soupbraa's Avatar
Default AP1 axle nut TSB gone wrong
I recently bought my s2000 and have driven it for 3000 miles or so (81,000). I started to hear a clicking/popping noise when taking off and sometimes even downshifting under a load. I went ahead and did the TSB the driver side went perfect and when I got to the passenger side it took about an hour to get the nut off. When I took it off the inside of the nut was almost a 1/4 stepped and rounded off inside. I ordered a new axle but when I put the nut back on to get the car back in the garage the whole hub is moving now. Is this a common problem?
Here is a picture of the nut and axle http://imgur.com/a/gGIk6
Old Aug 7, 2017 | 06:33 AM
s2000ellier's Avatar
you are suppose to do it with the wheel/tire on the ground
Old Aug 7, 2017 | 06:46 AM
soupbraa's Avatar
I did
Old Aug 7, 2017 | 06:52 PM
B serious's Avatar
the whole hub cannot be moving unless the wheel is spinning.
Do you mean that your car is moving when you try and put like 300LB of torque into the axle nut? That's not surprising. You should have the car in 1st gear with the parking brake on.
Old Aug 7, 2017 | 08:17 PM
BlueTeg's Avatar
Here is a picture of the nut and axle Imgur: The most awesome images on the Internet
When you say "the whole hub is moving" do you mean that the hub/wheel/tire assembly is rotating clockwise when you apply torque to the axle nut with the socket + breaker bar (or impact gun)?
Old Aug 7, 2017 | 08:43 PM
BlueTeg's Avatar
I would avoid putting it in gear.
Instead, I would pull the parking brake all the way up and buy a pair of solid rubber wheel chocks (available from Harbor Freight for about $7/each) and wedge them on both sides of the tire to prevent the the wheel assembly from moving when you apply torque to the wrench / breaker bar.
soupbraa
Aug 14, 2017 07:15 PM
Billman250
May 28, 2013 06:06 AM
badboy00z
Oct 20, 2010 04:18 PM
SLstone s2k kid
Dec 21, 2006 11:07 PM
Willie Gee
May 16, 2004 12:42 PM
