Ap1 Engine Check light & misfire! HELP!
Old Dec 30, 2012 | 09:47 AM
  #21
brummimatt's Avatar
Hi S2KIrishman,
I did it as per the DIY on this site. Steps below
Disconnected the battery,
Took all the coilpacks off,
took out the fuelling fuse,
took out all 4 spark plugs
screwed the compression tester into the first spark plug hole and cranked it 10 times
then the same in the 2nd port
then 3rd
and 4th
then i did them all again to make sure it was right. results were as i say, 100-95-92-97
I regapped the spark plugs to 1mm although i will replace them with new NGK asap next week when the shops are open. I also gave them a rub over with a small wire brush to get the carbon off.
When i put them back in, i reversed the order of the spark plugs but kept the coil packs in the same ports they came from.
I reset the ecu as well once i had put everything back together.
Now i have reset the engine light and driven about 5 miles and its driving ALOT better than before but still does have the misfire at low revs and especially if its in a high gear i.e. 4th /5th at low speed and i open the throttle fully. This is when it misfires badly.The light hasn;t come back on yet but when/if it does i will see if the codes change. if they do it must be the spark plugs
So... Any thoughts or ideas about the LOW compression readings? Not heard of sub 100 on any threads
Thanks
Matt
Old Dec 30, 2012 | 11:33 AM
  #22
JimEricksen's Avatar
This may sound random-- but the weather where you live-- is it cold and snowy?
Sounds EXACTLY like a problem my friend experienced when his CAI filter became clogged with snow/ice...
Jim
Old Dec 30, 2012 | 11:42 AM
  #23
brummimatt's Avatar
hi jim,
I live in London. Was pretty nippy when it all started to happen but its been about 5 - 12°C for the last few weeks so would think it would be defrosted by now? Think its worth taking the filter off and doing a compression test? is that risky?
Thanks
Matt
Steve P
Oct 1, 2015 12:13 AM
Smeek
Apr 17, 2014 11:17 AM
Lateralusticus
Feb 10, 2013 01:41 PM
mashu-sama
Sep 3, 2008 04:37 PM
ToEnvy
Feb 4, 2008 11:29 AM
