AP1 Flywheel or Aftermarket.
Old Oct 22, 2012 | 01:44 PM
S2K-In-Tn's Avatar
Default AP1 Flywheel or Aftermarket.
I will be replacing the clutch in my Ap2 this winter, i can get a decent used ap1 flywheel for around a hundred bucks. My question is, is there a down fall to going to a lighter flywheel then the ap1? just to save another 5 or 6 lbs on an aftermarket flywheel? Any recommendations on a clutch?
Thanks guys!
Old Oct 22, 2012 | 01:51 PM
GrandMasterKhan's Avatar
I highly recommend getting the ap1 flywheel. It's perfect. I went with the ACT clutch, OEM disc and AP1 flywheel with AP1 slave cyl in both my ap2s. Perfect setup makes the car drive and feel like a proper sports car.
Old Oct 22, 2012 | 01:58 PM
HvRRZ's Avatar
Aftermarket
Old Oct 22, 2012 | 05:54 PM
S2KPUDDYDAD's Avatar
AP1 fly wheel
Old Oct 22, 2012 | 06:27 PM
h i 9 h r 3 v z's Avatar
I would do AP1 flywheel.
Old Oct 23, 2012 | 06:16 AM
cdelena's Avatar
Driving with different weight flywheels makes a surprising difference and the reaction varies with driver. I personally think the car feels much better with a lighter flywheel and have a Toda in my car.
Old Oct 23, 2012 | 06:31 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Best advice you will get.
Ap1 flywheel
OEM disc from HONDA (not an oem equvalent found online)
ACT H021 Pressure plate
oem bearings
Old Oct 23, 2012 | 07:37 AM
HvRRZ's Avatar
You're going through the trouble of taking your transmission off to install a flywheel. Spend a little more and get an aftermarket flywheel now rather then going through the trouble again later. I never understood why people swap parts between diff models of a car. You install someone's AP1 flywheel, and they go install a lighter aftermarket one. Hmm I wonder who just benefited more?
I've tried multiple, and I can tell you that a good lightweight aftermarket one is a better improvement over the AP1.
Old Oct 23, 2012 | 11:57 AM
mazelmazelgoodthings's Avatar
Definitely just go with the AP1 flywheel. You can probably find one cheap because of the point HvRRZ brought up.
Old Oct 23, 2012 | 07:40 PM
S2K-In-Tn's Avatar
Thanks guys for all the feedback, i just recently purchased my s2000 so if some of my questions seem kind of ignorant i apologize. I love the s2000.. but as it sits factory, just should feel more agressive when going through gears.
So ap1 flywheel
Factory Honda Disc
Ap1 Slave
and act pressure plate.
