ap1 fuel pump doest it run continous once ignition is on
It should run for two seconds to prime the fuel system when the ignition switch is turned to the "ON" position then turn off.
It will turn on again when the start button is pressed and will run continously when the ECU senses engine rotation (ie. engine running).
If its been that way since you bought the car, I would check the wiring on the connector that goes to the top of the fuel pump assembly. Previous owner could have rewired that connector for direct power from the battery for an aftermarket pump and could have mucked it up.
It is common practice on forced induction S2000's to run a direct battery power wire back to the fuel pump and use a relay right at the pump to get higher voltage to the pump. This requires cutting and splicing of the wiring at the top of the pump assembly (or de-pinning of the wires from the connector). You may be able to see signs of tampering if you take out the three self-tapping screws that hold the pump cavity cover on and lift that cover up to look down at the connector that sits on top of the fuel pump assembly. Check all the wires that run to that connector for any splices or electrical tape, etc.
Andre
Feb 26, 2001 07:09 PM
