AP1 Intake Cam
Old Aug 21, 2008 | 09:55 AM
LlamaS2K's Avatar
Default AP1 Intake Cam
So searching around i learned that the F20c intake cam has an advantage over the F22. I also learned that the ap1 intake cam in a F22 head is ideal for FI applications. Anyways i aslo learned that if you were to put the IP 3mm HG on your engine you would need to adjust the cam timing.
cam adjustment
Basically i just want to make sure that even though the F20 intake cam is on a F22 head, i would still have to make the timing adjustments to compensate for the thicker HG regardless of cam.
Thanks
Old Aug 21, 2008 | 03:19 PM
AusS2000's Avatar
Of course. The head is sitting 2.3mm higher regardless of the cam.
Old Aug 21, 2008 | 05:12 PM
FASTSIIK's Avatar
ive been thinking about doing this also, how benificial would it be for N/A?
Old Aug 21, 2008 | 05:49 PM
h2oman104's Avatar
Im sure it would have benefits N/A also, given the AP1 intake cam has higher lift and longer duration.
cam specs
the stock specs are at the bottom.
Old Aug 21, 2008 | 05:54 PM
LlamaS2K's Avatar
Wait, so is the adjustment the same? In the DIY the guy mentioned that the cam gear had to rotated a certain amount. I don't remember what the exact number was but is it the same amount of rotation regardless of cam?
Old Aug 21, 2008 | 06:10 PM
AusS2000's Avatar
It really has nothing to do with the cam. You are raising the head 2.3mm. This means the top scissor gear is 2.3mm (probably about 2 degrees) out of phase.
If you read carefully the cam gear mod instructions you'll note that there is no adjustment as such. The scissor gear and timing chain pulley are held together by three bolts, but located with a pin. Removal of this pin allows a bit of play but not much. You simply remove the pin, refit the bolts, and then taking advantage of the play clock the chain sprocket clockwise a little and tighten the bolts. Probably gets you 1 degree closer to true.
Seriously, you're overcomplicating it.
Old Aug 21, 2008 | 08:51 PM
LlamaS2K's Avatar
OK, yeah i have i habit of over complicating things. thanks for clarifying.
Old Aug 21, 2008 | 09:21 PM
Stratocaster's Avatar
Also, for the record. There is only 1 S2000 Head. They are all the same. It is what is in the head that makes them differant.
Note: Only the 06+ head is differant. But only in the emissions porets, etc..
mrp3rs0n
Dec 5, 2016 04:13 PM
dc50818
Florida For Sale
Feb 9, 2015 04:45 AM
AndrewJM
Oct 13, 2014 03:55 PM
datbino
Sep 13, 2012 07:23 AM
lilboibounce
Dec 2, 2010 12:16 PM
