ap1 s2000 valves an retainers
Old Feb 28, 2021 | 03:28 PM
Static sean's Avatar
Default ap1 s2000 valves an retainers
hey guys i have a high millage f20 an im thinking of doing my retainers an i read a while back that going with ap2 retainers is a good. my question is it a direct fit on my head ? an do i do bolth sides or is just preferred on one side more than the other?
Old Feb 28, 2021 | 03:43 PM
darcyw's Avatar
No reason to change the retainers based on mileage- its not a wear item. Just do a valve adjustment and check the retainers. But, if you will want to replace them, only the INTAKE are done if you're doing it prophylactically.
And its retainers and keepers- 8 retainers/16 keepers for the AP2.
darcy
Old Feb 28, 2021 | 03:48 PM
okay cool thank you so the exhaust don't need to be upgraded to the ap2. or could i do it for the peace of mind since id already be there
Old Mar 1, 2021 | 02:42 AM
fernando.'s Avatar
No, the exhaust side does not need to be upgraded.
If you engine has never been over revved you do not need to replace the retainers, as Darcy said they are not a wear item, they only go bad if you over rev the engine which causes them to crack. I would inspect them first.
The Raptor
May 13, 2019 03:36 PM
scais2k
Nov 21, 2015 02:32 PM
gir89
Nov 10, 2015 09:42 AM
sdolla86
Nov 7, 2015 09:26 AM
cfolks7
Jun 30, 2015 03:04 PM
