Ap1 Shifter grummit
Hi guys
there is a small plastic grummit at the bottom of the shifter for the ap1 and ap2. Does anyone know a part number for it? Actually is it sold separately or do i hav1o to buy a new stick? mine is broken and the shifter is loose. Need to replace asap. |
Not sure what part you mean but if it's available you should see it here https://www.hondapartsnow.com/parts-...ift-lever.html
Thanks
It is part no 54111-S2A-003 Seems the correct name is Cover, Pivot Thanks a million |
Make sure you heat yours up (inside a ziplock bag in warm/boiling water) before you try to put it on, or you'll probably crack it.
I didn't even think of that, I will do that as soon as I receive it.
Gonna make the assumption to cool it down in some extremely cold water or even place it in the Freezer to get it locked on really tight. |
Do not cool it. You can also warm it with a hair dryer/heat gun until it is warm/hot to the touch and snap it on. The aftermarket also makes a bronze one. |
Originally Posted by Billman250
(Post 24428227)
The aftermarket also makes a bronze one. https://renegademotorsports.com/prod...-lever-bushing https://www.nengun.com/car-garage-am...0-shift-collar Looks interesting. Not sure it's worth $55 to me over the $16.58 from Honda. Most reviews are positive though. Do you run one of those Billman? https://www.s2ki.com/forums/s2000-mo...grade-1177029/ https://www.s2ki.com/forums/s2000-mo...piece-1030382/ |
I install for the guys but do not run one myself. |
Thanks for all the info guys.
I already ordered the Oem part from Hondapartsnow. What i will do however is to order another one as suggested from the links and upgrade. |
