Ap1 tranny, AP2 motor
Old Jun 19, 2007 | 10:55 AM
skyteg's Avatar
Default Ap1 tranny, AP2 motor
hi guys, if i have an ap2 motor with an ap1 tranny, do i need an ap2 or ap1 clutch?? or does it not make a difference!
thanks!
Old Jun 19, 2007 | 11:00 AM
AssassinJN's Avatar
Hm... why would u do this to begin with? Most people swap to the ap2 tranny because it has shorter 1-4 gear ratios and taller 5&6. (or is it 1-5 & 6??)
I'm guessing you ended up buying a ap2 for your ap1?
I would imagine the clutch wouldn't make any difference, but I'd go with an ap2 if there was an option. Or consider after market for slightly more $
Old Jun 19, 2007 | 11:08 AM
BlownAP's Avatar
Im guessing he upgraded his ap1 to an f22c, and still has the ap1 trans
everything should work,
Old Jun 19, 2007 | 11:17 AM
skyteg's Avatar
thanks! no it was the shop who swapped something they didnt know about!
i just ordered an exedy oem clutch.. i doubt ill have problems..
Old Jun 19, 2007 | 01:47 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Be sure to use the AP1 flywheel.
Old Jun 19, 2007 | 03:41 PM
skyteg's Avatar
ok thanks
Old Jun 20, 2007 | 03:44 AM
AssassinJN's Avatar
Hey Billman, why exactly is this? I have heard a number of ap2 owners "upgrading" to the ap1 flywheel but haven't heard exactly why (didn't really care enough to try and search it since I have an ap1 anyway).
Old Jun 20, 2007 | 05:16 AM
S2KPUDDYDAD's Avatar
The AP1 F20C Flywheel is only 14 pounds the F22C AP2 Flywheel is closer to 20 pounds.
Old Jun 20, 2007 | 05:20 AM
visionism0's Avatar
But are both flywheels compatible for either tranny?
Old Jun 20, 2007 | 05:39 AM
Yes, the entire clutch/flywheel will work on both cars, they are interchangeable. The heaver fly wheel will allow for a little better torque. The lighter one will raise the RPM
