Ap2 block w/ Ap1 heads.
Used s2k head bolts will provide much better clamping force than new ARP studs. But as stated they require precision measurement to be deemed reusable.
AP1 retainers will be fine, but require a very trained eye to spot early failure. So AP2 retainer and cotters are a good idea for that reason.
AP1 and AP2 (04-05) engine harness are plug and play/same.
If I was to use an aftermarket ECU & harness & change the inlet manifold, could I use an F20C AP2 08 engine in an AP1? I know the AP2 uses a different crank trigger wheel & cam trigger wheels, but could a aftermarket ECU manage this?
