AP2 A/C problem
Old Jul 3, 2013 | 05:00 PM
BLAQ&GREYs2k's Avatar
Originally Posted by KnottsHerrington
A while back the CRV had really bad issues with the compressor coming apart inside and indeed contaminating the whole system. For a while they were replacing the entire system under warranty. I've had to fix a few and have gotten away with doing a new compressor, receiver dryer, and desiccant. It all depends on have much contamination you have. Try and google honda hvac tsb
Ironic you said that, I had a 2005 CRV come in today that needed a compressor as well. The parts guy at Honda said they sell them left and right for those particular year model.
Old Jul 3, 2013 | 05:02 PM
Originally Posted by SouthDakotaS2K
A shelled compressor requires replacement of most of the downstream components. Those chunks of what used to be compressor get stuck in the passages in the condenser, evaporator,orifice tube/TXV and drier. If you don't replace all the parts and flush out the hoses those chunks will begin to break loose into the new system and may shell your next compressor in a short time. It is also imperative you measure the oil in the system and replace it exactly into a sealed system that has been vacuumed down properly. Best left to the professionals who have the proper equipment.
Agreed. Each component replaced has a certain amount of oil that needs to be injected prior to install. On the safe side it is good to replace the whole system if you have the money..
hybrid2.0
Jun 26, 2012 04:44 AM
svann
Nov 9, 2000 06:20 PM
