AP2 - Cruise Control Question
Old Jan 26, 2011 | 09:04 AM
J-Speed Inc.'s Avatar
Thumbs up AP2 - Cruise Control Question
Trying to figure out if there's something wrong with my cruise control or this is just how it works on the S2000. When I engage the CC for the first time, I feel it pull the pedal down and maintain the speed I want. If I cancel the setting or disengage the CC for any reason and re-engage it, the car slows down a few mph's and then accelerates to the speed I have set.
What's the deal here?
Old Jan 26, 2011 | 10:30 AM
03_BB_S2K's Avatar
its normal since the throttle uses cable. If it was DBW you wouldnt feel anything since its electronic.
Old Jan 26, 2011 | 12:41 PM
I understand that because there is a physical throttle cable, I will feel the pedal move when I engage the CC, but I can't understand why sometimes it engages immediately and other times it will allow the car to slow down and then accelerate it to the speed I've set.
Old Jan 26, 2011 | 01:10 PM
SilverS2kF22C1's Avatar
There is a set-up procedure for the CC module. I had taken mine out for some work and when I reinstalled it I had issues where it couldn't maintain speed and do things similar to what you described. I looked it up in the shop manual, re did the cable to the module and it was all good after that.
Old Jan 26, 2011 | 01:19 PM
19wrath85's Avatar
would you like me post the actuator cable adjustment procedures for you, its a very simple adjustment
Old Jan 26, 2011 | 03:04 PM
Yes please! That would be very helpful!
Silver, what cable did you have to re-do after installing your CC?
Old Jan 27, 2011 | 05:17 AM
The one that conects to the CC module it. Our cars (2005 here also) are not DBW AP2s (YESSSS!!!!) so they use a throttle cable to also control speed when using CC. The adjustment of the cable (slack) controls how the CC is applied and how easily the module can control speed. I had mine to tight so it was very jerky and couldn't maintain speed well at all. Once I adjusted the amount of slack in to the cable correctly it works great.
I can get the directions later this evening if needed. Just got to pull out the shop manual...
Old Jan 28, 2011 | 08:32 AM
Did you find the instructions on how to reset the CC?
Old Jan 28, 2011 | 10:17 AM
Side tracked with a snow storm last night and have an appointment these evening, I could have it for you in the morning.
Old Jan 28, 2011 | 12:50 PM
Great, thanks!
Sorry to hear about the snow storm, hope your S has tire chains!
