ap2 timing.
Old Jan 13, 2009 | 10:51 AM
crave13k's Avatar
Default ap2 timing.
hi im new here and i have a question. i recently purchased a 05 s2k. the car was in a wreck. so after changing all the necessary body parts i started with the engine. the timing is off. what i'd like to know is, what grove on the crank pulley is the crank pulley cover arrow supposed to line up with. i have a 00-03 manual but that manual only shows two lines. my crank pulley however has 4 lines. looks like this. I I I I . which one goes with the arrow? thanks in advance.
Old Jan 13, 2009 | 10:59 AM
tan0116's Avatar
I haven't checked the S2000, but in past Honda/Acura cars I've worked on I used the white tick line for TDC. You'll have to pop off the valve cover to make sure the cams also line up.
Old Jan 13, 2009 | 03:53 PM
Slows2k's Avatar
The white line is TDC..
If the timing was off the car wouldn't start with a OEM PCM.
Old Jan 13, 2009 | 07:17 PM
LostMotion's Avatar
Are you sure you are checking the timing correctly? Checking timing on a coil on plug motor isn't easy. What are you getting versus what you expect to see?
Old Jan 18, 2009 | 03:48 PM
crave13k's Avatar
does this look about right?
Old Jan 20, 2009 | 08:07 AM
crave13k's Avatar
bump
Old Jan 20, 2009 | 02:14 PM
crave13k's Avatar
can anyone help?
Old Jan 20, 2009 | 04:02 PM
Slows2k's Avatar
Looks like the cam chain sprocket is turned to far clockwise.
Old Feb 15, 2009 | 06:33 PM
Kirpich's Avatar
Take the serpentine belt off. It's so much easier to work with the crank then.
Take out the spark plugs. -//-.
Tehre are 2 marks: white and red next to each other. red is 5 degrees off. White is the TDC for Cyl 1. (or BDC, but you obviously don't want that.).
If this seems too confusing, you really should get an experienced guy to look at it for ya. But remember, White is the TDC. Red is 5 degrees before TDC, for ignition timing setting purposes.
Thomas Guide
Jan 28, 2019 01:30 PM
mz3ftw
Jul 1, 2014 07:58 AM
Jayboy83
Nov 13, 2013 11:28 AM
GDM S2K
May 5, 2007 11:24 AM
