AP2 Valve Retainer Upgrade gone wrong
Old Apr 10, 2012 | 10:58 AM
speedjunky01's Avatar
Default AP2 Valve Retainer Upgrade gone wrong
well got up early to get rocking on the AP2 valve retainer upgrade prior to the supercharger just for piece of mind, once I poped the cover all seemed to be 100% ok but I figured I have the parts why not?
got all the bolts loose in proper sequence
keeping it all clean and organised
then when I went to remove the 4th valve retainer
CLINK CLINK CLINK
X OVER 9,000!!!!!
I had air going in at about 30 psi but I guess it just want enough and for whatever reason it just dropped in
head removal time
I will get a new gasket should I just re-use the OEM head bolts? it just sucks because the job done by the factory is never really equaled at home
thats pretty much it thanks for listening to me vent s2ki and up the PSI if you are doing the valve retainer swap
Old Apr 10, 2012 | 11:37 AM
Switchblade's Avatar
That sucks!
Old Apr 10, 2012 | 11:47 AM
_brandon's Avatar
Dude that blows!! Atleast this happened with the motor off I need to do mine soon.. Will remember that, thanks for the headsup haha
Old Apr 10, 2012 | 01:00 PM
SLracer's Avatar
If the valve was able to drop all the way in that suggests you didn't have that cylinder at TDC which is why the cylinder didn't pressurize. Good luck with the tear down that's a bummer.
Old Apr 10, 2012 | 01:23 PM
Yeah I may have done the wrong one
Im going to pop off the intake manifold, grab it with the little finger grabber then through the massive f20c intake port (THANK GOD) use my fingers to pop it back into place
advice to anyone doing it
1 - 2 - 3 - 4
do 1 and 3 from removal of old to install of new
then rotate the crank 2 and 4 removal and install
may take a bit longer but my trying to save time you will regret it like I do now
Old Apr 10, 2012 | 03:24 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You dont need to pull the head
PM me your cell number.
Old Apr 10, 2012 | 03:25 PM
Billman250's Avatar
Top Answer: 1
Having the piston at TDC doesnt matter. Pressure is pressure. Many times the pressure will just push thew piston down anyway.
Old Apr 10, 2012 | 04:20 PM
s2klariat's Avatar
How much pressure do you recommend, Billman?
Old Apr 10, 2012 | 04:23 PM
s2000ellier's Avatar
When I did mine I used 30-35 psi and put every cylinder to TDC
Old Apr 10, 2012 | 05:42 PM
sent you my number billman hope you can be of help like the last few times!
