apexi vafc is it worth it?
Old Jul 15, 2002 | 10:38 PM
s2000coupe's Avatar
Default apexi vafc is it worth it?
the apexi vafc is it worth the money and how much horse power can you get out of it ? thanks alot jason p.s. how low can you make ur vtec go and run strong thanks again jason
Old Jul 15, 2002 | 11:32 PM
OneQuickS2K's Avatar
you can find your answer by searching the web site as this vafc question has been discussed for several times.
Old Jul 16, 2002 | 03:39 AM
turbo_pwr's Avatar
There is even a VAFC setting thread stuck on the top of this forum.
Old Jul 16, 2002 | 06:44 AM
s2000coupe's Avatar
i understand this there is just #'s
Old Jul 16, 2002 | 06:48 AM
turbo_pwr's Avatar
what? did you even go through the thread? it clear shows a dyno printout and vtec engagement settings. which are answers to your original questions. Depending on your car, tuner, and your mods with the VAFC, you can expect anywhere between 5 to 15 hp increases.
Old Jul 16, 2002 | 06:59 AM
KAMcDonald's Avatar
VAFC by itself should not really see any major gains.
reason for its existence is to make changes to the a/f ratio and vtec engagement to tune your car after adding i/h/e, sc, etc.
bolting on aftermarket parts may affect your engine to a point where the stock ECU cannot compensate for the change, so you use the VAFC, or some other engine management system, so adjust the ratio's to take better advantage of the mod.
as always, gains by the manufacturer or other people using a specific mod may differ from what you get based on multiple variables, weather, elevation, type of dyno, other mods on car, etc.
keith
Old Jul 16, 2002 | 07:04 AM
s2000coupe's Avatar
keith THANK YOU very much for explaning it! I guess i am gong to go out and get one thanks again jason
Old Jul 16, 2002 | 07:26 AM
bayarea408's Avatar
too much $ for too little gains
Old Jul 16, 2002 | 07:54 AM
marcucci's Avatar
$300 for 10HP? You can get this much even stock, if properly dyno tuned (maybe another $150?). I see people piss away more money on mods that do far less for power, plus this is one mod that will continue to provide gains down the road as you do more.
Old Jul 16, 2002 | 08:33 AM
MacGyver's Avatar
Kieth, what are you talking about no gains on a stock car? Our cars run so rich up top, the VAFC allows one to lean things up and get some power back out. Even on stock cars, there are measureable and significant gains to be had with this...
