ATE SL.6 Brake Fluid
Old Apr 26, 2015 | 09:37 PM
cosmomiller's Avatar
Top Answer: 1
Default ATE SL.6 Brake Fluid
Was shopping around for some ATE Type 200 and came across this link on the ATE website:
http://www.ate-na.com/www/ate_us_en/...bf_sl6_us.html
I have not heard of this "new" brake fluid they offer: SL.6
It has a slightly lower boiling point but it thin bodied for electronic braking systems such as ABS, VSA, and ESB. Seems like it would be easy to gravity drip/bleed and work well with the newer AP2s.
Can anyone chime in with any opinions?
Old Apr 27, 2015 | 05:14 PM
windhund116's Avatar
Has gotten good reviews on Amazon. Wonder if it is miscible with Typ 200, DOT 4?
http://www.amazon.com/ATE-706402-Ori...ywords=ate+sl6
Old Apr 27, 2015 | 06:07 PM
Answer I got from another board:
" In this case, I would not mix them (Type 200 and SL.6) at all. Type 200 is a normal viscosity DOT 4 brake fluid while SL.6 is a low viscosity brake fluid. Some manufacturer's require a low viscosity fluid and in some cars, the ABS system may perform better with a lower viscosity fluid. I would not recommend mixing two different viscosities together. You would be better off running 2 liters of SL.6 through your system which will effectively purge out the Type 200 and ensure fresh, air bubble free fluid in your braking system if switching to a low viscosity fluid is your plan."
Sev
Apr 29, 2002 04:37 AM
4373
Apr 16, 2001 12:18 AM
