axle or differentail issue
Old Feb 12, 2015 | 09:16 AM
Mr`revto9k's Avatar
Default axle or differentail issue
while I was under the car doing a differential fluid change, I noticed that the axle had backed it self out of the differential. So I took the axle out and took tout that axle shaft. I cleaned it up and freed up that locking ring. I put everything back but the shaft doesn't seem to stay locked in place, with a little wiggling I can pull it back out. I put back everything back and started the car and put it first gear and watched at the axle was rotating and after a while I could see that the axle shaft started separating again from the differential. What could be the problem here?
UPDATE: it looks like that locking ring was a little chewed up and so I removed it. Maybe if I install new one, that might help?
Also when I'm titghening the axle nut, the axle seems to get pulled towards the wheel and kinda gets stretched. Also how would I install the new locking clip without stretching it too much? thanks
Old Feb 12, 2015 | 02:25 PM
S2KPUDDYDAD's Avatar
The clip will slip on pretty easy. The dust shield on the stub axle should be straightened out as well.
Old Feb 16, 2015 | 07:33 AM
Mr`revto9k's Avatar
Thank for the reply.
I got the new clip and it seems to have a bigger gap than the old clip. It kind of fits loosely around the axle shaft. Is that normal or should I try to close the gap a little with pliers?
Old Feb 16, 2015 | 12:23 PM
No, your good to go...when you insert it, it will compress as it should.
DGomez
Jan 17, 2019 04:55 PM
BigBang
Nov 15, 2011 08:45 AM
dimi
Jul 20, 2009 11:47 AM
pdexta
Nov 19, 2007 05:28 AM
justs2knit
Oct 25, 2007 11:16 AM
