Axle nut, wheel bearing, or something else?
I have a noise that happens occasionally even after the axle nut has been torqued to 220 pounds. When very hot, like after an extended highway run (with periods over 90 mph) I can hear some cycling squeaking from the right rear when first getting to slower speeds. It goes away with cooling so I suspected a brake issue but cannot find anything wrong.
It also happens with heavy side loading through a turn. After the nut was tightened this was reduced but is still there with enough load.
I plan to re-torque the nut today using a little grease as it was done dry and may not be quite tight enough. Will also inspect the brakes again.
Is the noise of a failing wheel bearing substantially different that a lose axle nut? Any ideas or comments?
You said "right rear" first. When you load up in a turn, would this turn be to the left? (as in loading up the right side)
Xviper, Thanks for the complete review.. sorry to say you are probably right, I will need a bearing.
I greased and tightened the nut and got a bit more of a turn, maybe 1/8 more so it staked next to where it was. The noise is gone for now.
Too bad this has come up with only 40K miles on my car. I have about six weeks left on my extended warranty.. does anyone know if HondaCare has covered any wheel bearings?
wow, have this same exact problem. had that squeal and creaking just over a month ago. had both axle nuts greased/retorqued. well, a couple weeks after that, i get a pretty loud click when i load up the rear. it comes from the right rear, and happens 99% of the time when i'm turning right and accelerating from a stop. still havent replaced the bearing/hub. hasnt gotten worse than that one loud click, no squealing came back. make sure you buy the bearing and hub, just to be safe, the old hub may be messed up.
