back right wheel clicking
Old Apr 4, 2007 | 10:20 PM
gt489's Avatar
Default back right wheel clicking
ive seen it on here before but now im looking at my options. what do i need a new hub assembly and wheel bearing or do i need more parts cause the sound is pretty loud now. any help and leads to parts would be great thanx
gt489@aol.com
mike
Old Apr 5, 2007 | 04:11 AM
hondamanwill's Avatar
SOURCE: Honda Service News
TITLE: Creak of Grunt From Rear of Vehicle at Low Speeds
APPLIES TO: 2000-2005 S2000
SERVICE TIP:
Getting complaints from owners of '00-05 S2000s of a creak or grunt from the rear of the vehicle when cornering or driving at low speeds? The problem could be there's movement between the outboard joint and the wheel hub. To get rid of this noise, you need to clean and lube the mating surfaces of the outboard joint and the wheel hub.
Here's how:1. Remove the wheel nuts and the rear wheel.
2. Lift up the stake on the spindle nut, and remove the nut.
3. Remove the cotter pin from the lower arm ball joint castle nut, and remove the nut
4. Separate the ball joint from the lower arm.
5. Pull the knuckle outward, and use a plastic hammer to remove the outboard joint from the wheel hub.
6. Clean the mating sufaces of the outboard joint and the wheel hub.
Old Apr 5, 2007 | 07:27 AM
JimmyB's Avatar
What he said. I had the same problem and now fixed
Old Apr 5, 2007 | 08:51 AM
negcamber's Avatar
Make sure the hub nut is tightend to 220ft-lb.
Old Apr 5, 2007 | 03:56 PM
gt489's Avatar
had that service done and the noise came back
Old Apr 5, 2007 | 04:55 PM
jyeung528's Avatar
do it again.
Old Apr 6, 2007 | 03:10 PM
gt489's Avatar
i guess so
S2K-OED
Feb 9, 2016 06:44 AM
Nobody
Jan 27, 2014 04:26 AM
gbaker
Jun 27, 2012 04:07 PM
gtg749m
Apr 15, 2009 10:11 AM
YuriArts
Oct 22, 2007 01:33 PM
