Backyard Special Spoiler
Old Jun 13, 2005 | 04:35 PM
dp2580's Avatar
Default Backyard Special Spoiler
I was wondering how many holes you have to drill to install the BYS spoiler?
If you have to drill hole does it match with the 2 OEM spoiler holes?
Where a good place I can get the BYS spoiler? I'll take replicals.
Post up your BYS spoiler pics!
thanks
Old Jun 13, 2005 | 04:56 PM
dp2580's Avatar
wheres all the BYS guys!?
Old Jun 13, 2005 | 05:19 PM
Stratocaster's Avatar
You remember that this is an international board right? Some are sleeping other are eating. It has only been 30min between your posts.
And how does something that goes on the outside of the car, mounted to the trunk, qualify for an Under the Hood topic anyway?
BTW: Just poking you in fun.
Old Jun 13, 2005 | 05:45 PM
dp2580's Avatar
Old Jun 13, 2005 | 09:04 PM
SIIK2NR's Avatar
https://www.s2ki.com/forums/index.php?showt...ys+wing+spoiler
I'm pretty sure it bolts into the stock (5) brake light holes.
Old Jun 14, 2005 | 08:44 AM
MC21's Avatar
the BYS spoiler does not require you to drill any holes anywhere on the car, thats the beauty of it. It uses the 5 holes that used to bolt the 3rd brake light on the trunk; you will need to remove the 3rd brake light to install it.
It will not cover any OEM spoiler or aftermarket apoiler drilled holes.
when installing, you will want to use some 3M padded double-sided tape to put in between the spoiler and the mounting place(at the 5 bolting holes). This is not to try to hold the spoiler in place but to prevent scratching anything up(even places that you wont see) and to prevent noise/movement between the hatch and the spoiler AND, prevent water getting into the holes/trunk.
there is also a rectangle hole that you want to use some white silicon to seal it, so water doesnt get in.
I dont know where you can get a BYS spoiler now but I got one used with the help from Ben, Dickson and Justin @ AJ Racing
MC21
Old Jun 14, 2005 | 10:09 AM
dp2580's Avatar
thanks for all the info
MikeysFC
Jul 15, 2013 03:05 PM
MC21
Aug 27, 2009 10:54 AM
estukaye
16
Feb 8, 2009 09:53 PM
S2G-Unit
Mar 17, 2005 05:44 PM
Carlson
Nov 6, 2001 07:21 PM
