Bad leakdown test results
Ugh I have had a horrible string of bad luck recently. First I got rear ended at ~45mph while sitting still at a red light. Three months of chiropractic, physical therapy, and prescription meds later I get my car back and the CEL is on and body panel fitment is awful. It drives like ASS. I took my car to the dealer where they determined that the CEL was a cylinder misfire code on cylinders 1, 2, and 3. Did a leakdown test and got 6%, 16%, 8%, and 20% off. Jesus. Determined the spark plugs were worn, replaced them and did a carbon blast. Got it down to 6%, 8%, 8%, and 18%. Determined that cylinder 4 is leaking through exhaust valve.
I've babied the crap out of this car, it's never been launched, never been misshifted or overrevved, never been held in VTEC for a prolonged period of time.
The shop has suggested I pick up the car and see how it feels. Anybody have any idea how much work it is to remove the cylinder head and replace an exhaust valve & retainer?
I'm so frustrated I'm tempted to dump the car and drive a fricken volvo for the rest of my life.
You'll need to have all the valve seats and valve faces reground when the cylinder head is off. Figure 10-12 hours of labor to have a shop do it. You'll also need a headgasket, intake and exhaust gaskets, valve stem seals, oil, filter and coolant.
Originally Posted by Kremlin,Oct 7 2008, 03:13 PM
Yikes. Thanks guys.
The weird thing is that I was rear ended -- I have no idea why this suddenly popped up while the car was in the shop...
would be good if you did a leakdown and could prove the car was sound before the monkeys got a hold of it
you have to VTEC the SHIT out of the car to run Perfect
GL with your VTEC problem
MiKi
Originally Posted by Kremlin,Oct 7 2008, 01:21 PM
Does the ECU record overrevs in our cars? The body shop had the car for 3 months and put ~20ish miles on it...
OK this makes no sense at all.... you got rear ended in an 02 S @ 45 mph and the insurance repaired it? Was it a motorcycle that rear ended you? The car would be completely totalled if any normal car hit you...
